The primary reason for me installing a Big Brake Kit (BBK) is for sustained braking power while towing. I tow a 4300# trailer with the 6-speed transmission with no paddle shifters and need to ability to resist brake fade when descending. Heat is the enemy of brakes and my primary goal is to reduce negative heat effects. 2nd goal is stopping power in emergency. And a distant 3rd is looks – yes they do look better. This is a sizable investment for looks alone in my opinion, however.
First some administration:
This system will not be covered by any factory or extended warranty and I expect every dealer would deny coverage on this system. It will also limit the shops that may work on it and a dealer would not likely touch it – not a bad thing necessarily in my opinion. I do my brake work myself or could take it to a custom shop if I needed further help. If any of this is a concern for you, you should not consider this system. Turn back now.
This system will alter the operation of your vehicle from how the Honda engineers designed it. That’s the whole point, isn’t it? The expectation is that it will perform better. If you don’t like modifications and think stock is best, that is certainly your choice and should be respected. But that also means that this mod is not for you. Turn back now.
