Ok, it's raining, 60 MPH winds .. and its starting to snow. You need to open the hood and prepare for your good neighbour to give you a jump. Oh, right .. the Negative Terminal is under the Air Intake, .. ah, and that it under the plastic cowling with 9 clips. You are getting soaked .. you have a choice .. use the positive terminal and find metal for the negative or risk loosing clips, getting more soaked as you disassemble your new 2017 Ridgeline!.
Solution ..
Add a Boost, Jump Charge Plug. $20.00 .. and 15 mins work.
https://no.co/gbc007
Solution ..
