Hi guys I've had my 06 w/168k miles on it now for about 10 years, traxda lift installed about 5 years ago and bigger tires 265/65 r17 Cooper discoverer at3s for over a year or so, but I recently went back to stock tire size and decided to have my mechanic change out all 4 corners with complete KYB strut assemblies also put in 2 new lower control arms and got an alignment.
Right away I noticed that my coil catches/grabs on the top rubber area of the strut it's most noticeable when I first start my truck and turn the wheel, it makes a springy sound and pulls/jumps a bit. Also when I make a right turn over bumps, turning up a drive way, or any level change it makes a rattling noise kind of sounds like dropping a marble or nuts/bolts into an empty container..
Has anyone experienced this and did I get bad struts and need to go with OEM?? Oh by the way I later changed out the front sway bar links with the correct size according to traxda and also installed new sway bar bushings but noise is still there. Truck feels fine other than the issue above or when I'm driving straight haha, it doesnt vibrate plus everything looks tight and CV axles look good.. they're both OEM now with the passenger side being a month old and driver side being around 6 months old..
Thanks in advance!
Sent from my SM-G965U using Tapatalk
Thanks in advance!
