41 - 60 of 168 Posts
My experience suggests that the economy figure that the truck produces can be pretty far off (and optimistic). When I began using Fuelly to track my MPG, the numbers weren’t as good but at least they were true. I average 23.5 - 24 through light throttle pressure and looking ahead as much as several hundred yards. I coast to a light if it’s clear I’m not going to make it through under green. I try to leave a little early so I won’t feel pressured to drive ‘more enthusiastically.’ My wife’s foot is either on the gas or the brake but when possible, I’ll just coast. Psychology is a funny thing; when I’m in the Honda I drive differently than when I’m in the Audi. I will add that I live in Texas where the average cruising speed will earn you lots of fines in many other states. 85 mph is just going with the flow in TX. It’s great.
I just came back from OK-SC averaging 24 mpg. I probably had a average speed of 60-65. My ridgeline also has x bars & roof rails, bikes & gear. I didn't use eco & played around in sport mode. Eco does seem to help if you use cruise, eco and no hills. I also feel that eco gives you slightly better mpgs but eats more gas.
G2 RT-LE owner: I concur, the fuel economy shown on the dashboard is frequently 1-4 mpg higher than I calculate at each fill-up. I owned the G1 truck and it was slightly more accurate but nowhere near as accurate as the mpg figures my Genesis GV70 reports. Reported vs calculated in the GV70 is almost spot on whereas the G2 RTE is an overly optimistic estimate.
As stated, wind resistance/force required goes up exponentially with speed. I can get 30mpg in my RL at 55. No way at 80 mph..... Air up tires to max, oems, probably 44 psi. I never use ECO mode but I will use the 'S' mode' to shift less aggressively while cruising the highway. Of course be sure all your filters- engine air in particular, are fresh.
"S" is Sport Mode, higher RPMs between shift. How could that improve MPG???
Time for our first road trip in my 2023 RTL, which has just under 10k on the clock. I currently get 21 mpg according to the meter on the dash. Since we will be traveling approx. 900 miles each way (Atlanta to Wichita), I am interested in hearing any tips to improve my mpg.
Truck is factory standard, including no bed cover. I’ve been using regular fuel. Two passengers, and don’t anticipate carrying anything more than light luggage and a med size cooler.
Thanks for any advice-
We took our 2022 RTL-E from WA State to Maine and back last summer. 7,200-ish miles. Two people,golf clubs, and luggage. Averaged 24.3 mpg with 2-lane speeds of 65-70 and freeway speeds of 75-80 mph. All on regular gas.
Only suggestions I can offer is to consider a bed cover and removing cross bars on the roof rack(if you have them)
Have a great trip! Ridgeline is a wonderful road trip vehicle.
Drove to East Texas from Savannah, GA (900+ miles) last November, and was getting 25/26 mpg in my '24 BE. I think I was running 75 mph with the cruise set.
Hello,
I have a 22 Blackline and just came back from a 500 mile trip and got 26 MPG.
Here are some tricks for better MPG
Tonneau cover (without one proven to make the bed an air drag)
Fuel injector cleaner about every 3 tanks, remove deposits from Ethanol.
Ethanol robs fuel economy, proven
Make sure the tires are inflated, I run mine a 34-35 PSI
Use your cruise control. way better fuel economy
Great vehicle, let is do the work...
Safe travels
Honda does not recommend using additives. If you use Top Tier fuels you will be getting a higher level of detergents in the fuel. In a modern sealed fuel system like on the RT, if you are getting deposits, it's not from the ethanol, you have other problems.
Ethanol does not "rob" fuel economy, it has lower BTUs available resulting in lower MPG at a lower purchase price. Do you consider purchasing non-ethanol fuels to be robbing you financially with the increase cost per gallon?
I have found the older transmission to more reliably get better millage. The newer ZF is more...shift happy and tends to want to go onto lower gears more easily more often. It rewards a VERY light foot but punishes everything else.
However,
I have been able to force better mpg, up to 5-6mpg better, by forcing manual shifting and forcing higher gears as much as possible. I can go into snow mode and sport mode to get a 2nd gear start, more linear throttle map, a program that favors up shifting and low RPMs, and with sport it'll also indefinitely hold a gear unless impossible for the speed. Doing this I can push a 21 mpg avg mixed city commute to 26 mpg, a number it will never automatically achieve, and this is also forcing more awd rearward in snow mode which should be a slight negative.
But it's also a matter of how much you want to force low rpm and lugging the engine in high gears.
On a side note, the newer refresh is a little less aerodynamic. I have a 2021 and had a 2017 to 100,000 miles. On highway, the newer boxier shape hurts highway. My 2017 always got 31-33 and up to 36 mpg on occasions. My 2021 struggles for 31 mpg on the highway at the same speeds.
This is quite possible - how ECO mode affects the throttle response could actually have negative impact on fuel economy, depending on how the driver uses it.
Recent discussion on this exact idea! I find myself almost daily saying "More than one thing can be true at the same time", for various topics.
@Flatwound - ECO mode is rather controversial on this board, as is the Auto Idle Stop. I notice that not many of the naysayers share pics of their achieved MPG, so take that for what it's worth. ;) I don't intend to be an ECO or Auto Idle Stop apologist, I just like hard data on what actually works to maximize MPG and minimize fuel cost.
In fact, I have an open challenge to beat my posted 31 MPG without using ECO for some free Ridgeline accessories - still no takers. I really want to know if ECO isn't useful, but I only have data on extreme MPG achieved while using it. My long term MPG averages around 23-25 MPG, but my commute to work is only a few minutes - not the best for optimizing fuel economy.
If you want to learn more about ECO mode, some good, reliable info here:
https://www.ridgelineownersclub.com/posts/2178058/
https://www.ridgelineownersclub.com/posts/3344631/
Short answer to "what does it do"?:
  • Remaps the throttle pedal (have to push it more to get the same throttle response), kind of opposite the Pedal Commander.
  • Lowers the blower speed when the A/C is on
  • Adjusts when the Auto Idle Stop restarts the engine.
Thanks, I never thought about the factory service manuals being available in the library.
My best advice for long trips (nothing extreme here, but just the basics):
  • Use ECO mode
  • Try to keep the green ring around the gauges lit (not white), and keep an eye on the MPG readout.
  • Let Auto Idle Stop engaged so you're not burning more gas at red lights.
  • Take your time, avoid heavy acceleration and braking, and don't speed - this is probably the biggest one.
By following these basic ideas, I achieved 31+ MPG on a roughly 440 mile round trip from my house and back over a long weekend, with a few (3 or 4) short trips of city driving in between. I also have a 2023, I don't buy special gas, just regular 87 octane at whatever station is convenient on the way. It was a similar situation - two passengers, with luggage, no bed cover.
More info here:
Let us know how it goes!
I know one thing for sure, idling kills your gas mileage. I have to leave my truck running sometimes when I run into the store because my wife is disabled. The mileage can drop a couple mpg in just 15 minutes and it takes quite a few miles to get back to where it was.
By far the #1 factor: Speed.
As stated by others, drag is a square function. So 2x the speed = 4x the drag. If you want good fuel economy and don't care about making enemies on the interstate, you can follow a semi. You don't have to tailgate to see gains. Even following at a reasonable distance will help.
When cruising down the road, ECON helps your fuel economy slightly, but maybe not in the way you may think. The most obvious thing that ECON does is re-map the throttle pedal, giving a much slower start. When cruising down the road (especially with cruise control on), this does virtually nothing for fuel economy. But what also happens is that ECON mode slightly "loosens up" your cruise setting, allowing your Ridgeline some leeway. So when going up a hill, your speed may decrease a bit more in ECON mode. This immediately gets back to the first point - speed. Because ECON allows slightly slower speed going up hills, you'll get slightly better fuel economy because of the reduced drag. You certainly don't need ECON mode to achieve the same results. If you just drive 1 or 2 MPH slower, you'll be able to beat the ECON gains. It's just that ECON does this for you automatically. The other thing ECON does is to alter your air conditioning. ECON reduces the cabin fan speed which causes less heat transfer across the evaporator which causes longer delays between the compressor running. I think I read somewhere that ECON also allows wider evaporator temperature swings which also causes less frequent compressor cycling. The point is that ECON produces less robust air conditioning for a slight economy gain.
Outside air temperature plays a role, too. I commute every work day over 40 miles each way, and we take the Ridgeline on road trips because it is so comfortable. So I put well over 2,000 miles per month on my Ridgeline. I've been keeping close track of my fuel economy since last June. This graph is my hand calculated economy. On average since last June, my dash indicated economy is 0.7 MPG higher than my hand calculation. As you can see, outside air temperature plays a fairly significant role:
Note that I have my Ridgeline set up to automatically disable Auto Idle Stop using a time delay relay to automatically turn my power inverter on, and I have an S-VCM Controller to defeat Variable Cylinder Management. I drive 100% with ECON turned OFF. I carry around lots of tools, so my vehicle weight is probably higher than most.
Interesting. Before agreeing to temp change affecting the MPG, I would investigate summer vs winter fuel mixtures.
I do believe a bed cover will up your mpg by 1 or 2 miles—which can add up on longer trips. We drove 1800 miles round trip in January and averaged 23 mpg in 2022 RTL-E.
I agree that winter blend fuel will slightly decrease economy, but that change should be rather sudden and does not account for the gradual downward trend as it got colder for several months in a row and now the gradual upward trend as it's just starting to get warmer.
Lower speeds and stay to the right (slower lane). Wind drag is a geometric progression related to speed.
Light weight bed cover helps.
Others have covered the other things that help. $s per gallon for gas is dropping down this way. Safe travel!
