1 - 8 of 8 Posts
Surfer111
Discussion starter · #1 ·
Has anyone bought TRQ’s rear struts and replaced it on their ridgeline? I bought the left and right rear struts from TRQ. But the “RR” doesn’t align properly with the upper mount holes. They say you can spin the struts to align them properly but I can’t seem to do so. Should I figure out how to mount the top and try to rotate the bottom with a long screw driver or something so it can align? I don’t want to break anything and I’m a newbie mechanic so any advice would be greatly appreciated!
Pictures?
Discussion starter · #6 ·
Been a long time since I replaced struts on anything and never on a Honda but maybe this will help:
Thanks I’m using this video to replace them. So far I got one side done but the rear left has been a S**t show. Sway bar link rusted. Had to cut it off and I don’t have access or an angle to the top hole. I’m not quite sure how people install new ones.
for the top 3 bolts, I broke of the nuts that are welded in. I heard you can take off the wheel well liner and access the top. Will try that and see how it goes.
I jusssss put some on this past weekend…you can rotate the top counter clockwise until the holes line up!
1 - 8 of 8 Posts
