Forgive my ignorance, but what is VCM? What does or doesn't it do? What are the benefits of disabling it? Thanks.
Variable cylinder management. Under light loads, 3 cylinders are deactivated IOT save fuel. Various car companies have used this, but often with poor results. GM in the 80s had a disastrous situation with the 4,6,8 Cadillac. Honda had problems with their V-6s in the 2000s up thru 2016: fouled plugs, excessive oil consumption, and cylinder wear on the deactivated cylinders.
Lots of speculation as to why: uneven heating of the block, rings not under compression pressure causing wear, etc. I had the VCMuzzler 2 on my 2017 from early on thru 82,000 miles. It used zero oil between changes. FWIW, our 2013 Accord EX-LV-6 didn’t have deactivated VCM and is still fine at nearly 100K miles.
Though I found nothing published, VCM was used with the V6 used in the Ridgeline. I’m not aware of what changes are in this version of the 3.5V6 other than direct injection verses port injection.
Why is it ok now, but problematic before???
Just this afternoon, I called and discussed this very matter with the service representative at my local dealer. He didn’t know why there are not problems with this DI engine but they’re not showing up. I’ve decided that since my ‘22 Ridgeline has a lifetime power train warrenty, I’ll disconnect the VCM2 that I’ve had installed for these 1st 2 thousand miles.
Again, I can’t find out why it’s ok now but wasn’t then. My service manager says it hasn’t been addressed that he can find.
Deactivating comes at a cost of the device and about 1 - 1 1/2 mpg.
There are arguments each way.
