I have a 2024 Honda Ridgeline Sport that I purchased around 55 weeks ago. I have been doing oil changes and tire rotations at 5,000 miles instead of waiting for the MM codes to get to 15%. Today I hit 15,000 miles and the code A6 come up (previous codes were all A1 I think).
So I take into dealer for service (because I have 2 years free oil changes and tire rotation) and also request drain and fill of the rear differential fluid as per A6 MM code. The service writer writes up that service but also states that Honda recommends alignment and front transfer case drain and fill at 15,000 mileage as well. I was under the assumption that front transfer case fluid/transmission fluid would be done at the same time under MM code A3 (which I've not seen yet). I know the alignment is probably just a random upsell but is he wrong about front transfer case fluid replacement also being part of A6 service? Is that not under A3 and hence not necessary at this mileage?
