I know this has been done but let's get some statistics.
That's what I thought, but wasn't sure.DoctorJ said:Swamp its 87.
I use 87. I've noticed (on the road) that many stations offer 87 and 89 at the same price, however the 89 is ethanol enhanced.DoctorJ said:I know this has been done but let's get some statistics.
Not upscale vehicles, but higher compression engines require higher octane fuel. Most any EFI engine can compensate for a lower octane fuel by retarding the timing which intern lowers the gas mileage and power.tinsoul said:IMHO, the only cars that really need the higher octane are '60s musclecars. As a side note, I've owned two 1990 Jaguar XJ6's that were labelled saying to use only premium, but following the advice of the Jaguar forum I used to frequent, tried and kept using 87 octane. I still have one of the Jag's now. No detonation/backfiring/hesitation. Always passes smog checks and has plenty of power. I just mention the Jaguar because a lot of people are under the false impression that upscale vehicles would require more expensive gasoline. Not really so.
Depends on what you mean by "need".tinsoul said:IMHO, the only cars that really need the higher octane are '60s musclecars. As a side note, I've owned two 1990 Jaguar XJ6's that were labelled saying to use only premium, but following the advice of the Jaguar forum I used to frequent, tried and kept using 87 octane. I still have one of the Jag's now. No detonation/backfiring/hesitation. Always passes smog checks and has plenty of power. I just mention the Jaguar because a lot of people are under the false impression that upscale vehicles would require more expensive gasoline. Not really so.
Plug up your cat, where do you get that information from? Higher octane will burn smother and cooler than lower octane fuel. The only way it will not burn completely is if the air to fuel mixture is wrong.613Ridge said:If you use to high an octane, it won't fully burn, and the unburnt fuel will pass through your catalytic converter, plugging it up.
Not so sure I buy the cooler part, and the smoother part is also a little questionable. This is my understanding of it, and feel free to point me to corrective information.DoctorJ said:Plug up your cat, where do you get that information from? Higher octane will burn smother and cooler than lower octane fuel. The only way it will not burn completely is if the air to fuel mixture is wrong.
We found that to be true on our latest trip. Our first trip towing with regular (86?) we only got about 12 mpg. This trip we used premium (91?) and we got about 15 mpg. No noticeable difference in performance but the mileage was better.5S Dude said:I've read elsewhere on the net that if you pull a large loaded trailer up mountain roads, that a higher octane can be of some benefit. Is this true?
I doubt that you would ever get any pinging in the RL. The anti-knock sensors in the engine would compensate by changing the timing and would result in a loss of power, but no pinging.The way to tell is if you get any pinging. If you do, get thee to a high octane pump. If you have a full tank of 87 and start pinging you can use some octane booster to finish the tank. If you aren't towing and aren't pinging you are wasting money if you use higher octane.
Hi Monte! JMHO, but feeling the engine run smoother (if that's possible!) and more responsive, is worth the extra two dollars more for a twenty gallon fill-up. I'm still tracking my MPG with 89. It seems to have improved, at least on highway. We'll seeZemog said:Hey, the manual says 87 octane so thats what I use. Besides, it's cheaper!
