2020 with 24000 miles alignment
8.5K views 26 replies 11 participants last post by  millerbl0
I have a 2020 with 24000 miles. as you can see the rear alignment is off.
Questions:
1.) Tech said it drove straight and this will not cause tire wear. TRUE or FALSE?
2.) Will the Honda warranty or extend warranty cover this?
3.) can I get my frame shop to elongate the struct tower holes to give more adjustment?
what are my option? Truck has not been wreaked or abused
thanks
THIS^^^ NEVER EVER modify the frame!
#10 ·
Not sure it would affect it overall too much, but wonder how much of this pre-alignment checklist was followed to the tee (especially, like full tank of gas, spare, etc):
For proper inspection and adjustment of the wheel alignment, do these checks:
1. Release the parking brake to avoid an incorrect measurement.
2. Make sure the suspension is not modified.
3. Make sure the fuel tank is full, and the spare tire, jack, and tools are in place inside the vehicle.
4. Check the tire size and tire pressure according to the tire information.
5. Set the steering column to the middle tilt position and telescopic position.
6. Check the runout of the wheels and tires.
7. Check the suspension ball joints (Raise and support the vehicle. Hold a tire with your hands, and move it up and down and right and left to check for movement).
8. Before doing alignment inspections, be sure to remove all extra weight from the vehicle, and no one should be inside the vehicle (driver or passengers).
9. Lower the vehicle to the ground. Bounce the vehicle up and down several times to stabilize the suspension.
#23 ·
This alignment problem sounds hauntingly similar to my past '13 CRV AWD. A Firestone dealer insisted on an alignment with a set of new tires at 35K miles. So sure... make sense to have this done. They attempted to adjust the "out-of-spec" rear axle camber (non-adjustable). Afterwards the entire vehicle shook & shimmied so bad I took it back twice to get this readjusted. Then, they claimed the vehicle was defective & couldn't be set correctly so voided the warranty on the new set of tires. They had it so screwed up that my Honda dealer had to fix it. The Honda tech came into the waiting room asking..."WTF was wrenching on my CRV?" It took him a couple of trial & fail attempts on their alignment rack to get this reset correctly. My advice is if the truck is handling correctly, leave it alone.
#26 ·
Unless you’re seeing abnormal tire wear or having handling symptoms, I wouldn’t worry about it. Camber is dependent on ride height. My guess is you could jump up and down in the bed a few times and get a different measurement. The aftermarket kits are really for those who raise or lower the factory suspension. Plus a little bit of negative camber will shave off time from your Autocross runs.😀
