So I just put in new speakers in my 2024 Trailsport and though I noticed an improvement, I felt that the difference should have been more pronounced. Suspecting that the stock head unit was likely applying some sort of EQ to the signal, I dug into the hidden menus of the stock radio to look for some sort of setting to make the EQ flat - and I found that setting! The sound system sounds MUCH better and it seems to remember the setting even after turning the truck off. Here are the steps, try it out and let me know if you notice an improvement. Unsure if this works on the Black Edition or on pre-2024 models.
1.) Turn ignition on in accessory mode. Don't start the engine.
2.) Hold down the Power, Home, and Previous Track ( <<| ) buttons simultaneously for around 5 seconds till you hear a beep.
3.) You will now see a white and orange menu screen. Select the bottom option, something like "diagnostic settings". Don't select the "self-test" option on the top half of the screen.
4.) Now, hold the Home button till you hear a beep.
5.) You'll be at another menu now. Select Audio Settings.
6.) Now deselect "PS Audio".
7.) Press "return" on the top right corner until you've exited the diagnostic menu.
8.) Test out the new, clearer audio!
