Does anyone know if there is enough room (depth) behind the top "cubby" hole just below the rear seat A/C vents to put this USB adapter in place ? Its about 1" long....I don't want it to interfere with the console "rolling" door...
Big help thanks !A while back, I needed to disassemble the rear console in my '21 RTL to research adding something (I can't remember anymore).
@zroger73 sent me the following instructions that were very helpful. I did not fully remove the console, but I did get the outer panels removed.
I will also include the pictures I took of that rear section. Hopefully, this will help you. If I recall, removing these panels were not that difficult.
Good luck, @fdeno.
