Another Stereo Wiring Question
2.3K views 11 replies 6 participants last post by  komodopb
Hi Guys,
Let me start off by saying this is an excellent site as you guys have already answered/solved many questions even before my first post. Let me also apologize if this has been answered a 1000x's but I've been searching for a few hours and can't find the thread that explained this. I just picked up my 2011 RT and I'm changing out the HU as I can't believe Honda still doesn't make an aux input jack standard on all models. I have a JVC HU from my last truck that has the aux input (for my Sirius radio) and controls my iPod. I picked up the wiring harness and antenna adapter kit from scosche and I'm not sure what to do with the blue wire on the antenna adapter. I thought I read somewhere that it goes to the remote turn on/power antenna wire? Please advise if this is correct or does it need to go to the radio 12+ volt wire. Also,it's been a long time since I've installed a stereo- the unit does not have Dimmer or Illumination inputs but the Honda harness does. Please let me know if I'm correct in just taping these up and leaving them unhooked.
I thank you all in advance!
#2 ·
Welcome to the ROC! and post pics asap!
I don't have an answer for you but I'm sure someone in the ROC community will chime in soon. :act035:
#3 ·
Will do! This is a big weekend for me as the nerf bars, rear mud flaps and Westin bug deflector are suppose to be delivered today! I already installed an aftermarket trailer wiring harness on Tuesday (but after reading some posts, I wish I bought the factory harness), and plan on getting the radio and Sirius installed.
It is used to power the amplifier in the OEM antenna. You should connect it to a source of switched 12V power, i.e. the radio power. Expect to be less than impressed with the antenna, it sucks.
#5 ·
it can got to the blue wire which is for power antennae or the blue/with wire which is amp tun on. it only makes a difference if the car has the older style power antennae that went up in the air. If hooked up to the blue/white the antennae would stay up for as long as the radio is on.. with the blue wire power is cut off to it when you put in a cd and not listening to the radio.. as for the dimmer wire and illumination, they are not necessary.
so you can use blue or blue white, i personally would not use the ignition wire or switched 12volt since it is powered by turning the ignition on and not the radio.
Just to add a bit to Shovelhd's post - the Ridgeline radio antenna has a signal amplifier. It needs +12V to power it. If you do not supply +12V to that blue wire, the signal from the antenna will be nil. With power, it rises to barely satisfactory.
So connect it to a switched 12V wire.
#8 ·
Much appreciated, thanks for the help guys- I'll hook it up to blue/white remote turn-on.
FYI, I find the reception to be pretty good on my 2011 (I've read a lot of complaints about the reception), maybe they changed something? But honestly It doesn't make a difference as I only listen to satellite nowadays. I just wanted to make sure I hooked it up properly.
#9 ·
Don't do that. Use a switched 12V line with sufficient ampacity to power the amp. Remote signals are often less than 12V and don't have a lot of oomph.
#11 ·
The switched wire. It should be red but I don't know if you have a CEIA compliant harness or some cheezy eBay special.
