What have folks done to get rid of the trunk smell? After more than a week of trying to let it "air out" it's still really strong so it's time for chemical warfare.
no need to do that.. the light turns off after 30 min and doesn't effect the battery. i leave mine open every night in the garage.I have found a short stubby phillips screw driver in the latch when the lid is open turns off the rear lights. This makes the lid think it is closed while airing it out over night. Just hit the lid open switch and the screw driver in the latch drops out allowing you to close the lid before driving. This keeps you from running down the battery while airing out the stink.
That's correct. Plus, you don't have to worry about forgetting to remove the screwdriver and shutting the trunk since the warning indicator will still function.no need to do that.. the light turns off after 30 min and doesn't effect the battery. i leave mine open every night in the garage.
Lid open switch??Just hit the lid open switch and the screw driver in the latch drops out allowing you to close the lid before driving.
i think he's talking about the button that opens the trunk at the rear of the truck.Lid open switch??
Now I have to go look. I was unaware of a button or switch.i think he's talking about the button that opens the trunk at the rear of the truck.
You've never opened your trunk before?Now I have to go look. I was unaware of a button or switch.
it's a button in there you press that opens the trunk lid if you pay attention.Frequently. I grab the handle and it opens.
Or you could simply push the button in the cab for the rear light after you open the trunk. It will also instantly turn off the light, or back on.Yes I understand what that after 30 minutes the both lights go off this would turn them off instantly.
OK, that makes perfect sense now. :grin: I was under the impression that ItsaTruck meant a separate switch or button.it's a button in there you press that opens the trunk lid if you pay attention.
This! Why would you not do this?Or you could simply push the button in the cab for the rear light after you open the trunk. It will also instantly turn off the light, or back on.
because it's not necessary? you get out of the car...go to the tailgate...swing it out...pop open the trunk...and that's it. there's no need for the extra step of walking back to the cab, opening the door and pressing the button to turn the light off...the light turns off on it's own after 30 minutes and doesn't effect anything.This! Why would you not do this?
Yep, I see your point. But no need to wedge a screwdriver in there either. Since I park in the garage, I have to walk back passed my driver's door to get into the house anyway so I'll keep hitting the button :smile:because it's not necessary? you get out of the car...go to the tailgate...swing it out...pop open the trunk...and that's it. there's no need for the extra step of walking back to the cab, opening the door and pressing the button to turn the light off...the light turns off on it's own after 30 minutes and doesn't effect anything.
