Has anyone tried this fix to the driver side seat bolster?
I took a mirror and looked under my seat to see if the bolster foam is accessible from the bottom like this guy's seat and it appears that it is. Whether I can get new foam crammed up in there like he did is another issue but definitely worth the effort if the seat is fairly easy to remove. $30-40 worth of foam and an hour's time beats $400 and 2-3 hours time to replace the leather cover and cushion. The leather is in good shape except for the wrinkles and collapsed bolster.
Mine is a 2020 RTL-E with 43K miles. I just bought it used so the guy that had it before me was pretty big and the side bolster is soft as a pillow underneath. I think if I can cram some stiff foam up in there it will fix this issue for the most part.
I understand that I may need to disconnect the battery before unhooking the yellow airbag connector but not sure if it is a requirement.
Thanks.
Thanks.
