Sure, disconnect the temperature sensor so the heating coil won't come on....oh wait....that might not be a good idea.....you might run the risk of hydrolocking your refrigerator...
Well, to avoid the possibility of Refrigeratus Hydrolockitus, it's a simple mod in addition to HP's suggestion of disconnecting the temp sensor. First, you need an Arctic Spansor Hydrometer, readily available at your local Appliance Repair Shop; expect to pay in the neighborhood of $35 for the tool.
Once you have located the tool, you need to apply it to the Acqua-Sprocket Spring Tensioner in a counter clock-wise rotation with 8.2ft/lbs of torque. Warning: Do NOT over torquer the spring tensioner as this will lead to refrigerator hydrolocking if the temperature sensor is disconnected.
Once the Aqua-Sprocket Spring Tensioner is set to the correct torque, you will be able to release pressure from the heating coil. Note: It is a common myth that refrigerators do not have heating coils, as this is counter-intuitive to the whole "cooling" feature of the refrigerator.
With minimal or no pressure in the heating coil and the Acqua-Sprocket Spring Tensioner set correctly, you will be able to enjoy a thick and lustrous blanket of frost build up in your very own refrgerator. This frost is also compatible with the optional SnowConeus Adapter, which creates a wonderful surprise after dinner treat for the family.
Disclaimer:
No fur-bearing animals were harmed during the creation of this post. Allergy alert: may contain nutmeg, but we doubt it. Return for refund where applicable. Not recommended for persons with sugar-restricted diets. Batteries are included -- best of luck finding them. Proud sponsor of the 1934 penguin Olympic games at McMurdo Sound, Antarctica. May cause irritability, sleeplessness or warts after prolonged use. BHT added to preserve freshness. Caution: this product has caused some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Shake well before using. No vacuum tubes or other user-serviceable parts inside. Not to be combined with other radioisotopes except under the advice of a physician. Avoid prolonged exposure to ultraviolet light. The truth is out there. Use no hooks. Not intended for use by children or liberals under the age of five. Created with unrecycled electrons and we're proud of it.
