Some of you may have seen this already.
There is a new supercharger & intercooler kit for the port injected J-series. This is more mindful of the space constraints in a J-series equipped engine bay and is designed to operate with a air-to-water intercooler that sandwiches between the cylinder heads.
This kit is made by Boosted Engineering & Fab Inc (Honda J-Series Supercharger) based in Victor, NY. Costs anywhere between $3500 to nearly $8000 for the kit alone and capable of mounting a couple of different supercharger bodies. As many of you know, this type of performance is costly, and often times includes a full rebuild of the motor and adding other supporting modifications (cooling, exhaust, suspension, tires, tuning, etc) can nearly quadruple the value of our G1s - thus this is really for serious enthusiasts only.
The kit includes (from website)
So all in all - this is a full kit from start to end. I dont know anything about this company nor do I have any affiliation to this group. I stumbled across them in one of the Facebook performance groups I belong to and found their packaging to be as near as the designs I have sketched. They use a lot of 3D modeling and rapid prototyping which is really neat.
This now adds an option to a market that is supported by Prank Parts and Gerzy Bear Performance.
- Supercharger body
- Lower manifold
- Fuel rails
- Supercharger mounting plate
- Throttle body mount
- 8 psi pulley
- Belt
- All hardware
- DBW throttle body extension
- Injector extensions
- Knock sensor
- Power steering line bypass
- PCV
