1 - 1 of 3 Posts
DMac84
Discussion starter · #1 ·
Hey guys, long story short, I backed my 06 RTL into a barrier at a gas station. Cracked my rim and bent my trailing arm. The emergency brake line runs through the trailing arm, so the e-brake cable must be disconnected. In order to do this, I must remove the rotor disc. How do I go about doing so?
I looked online, and saw where you had to remove two screws from the disc itself and it should come off. Only problem is, there was only one screw. The other screw looked like somebody (Previous owner/shop) had broken the head off while trying to remove the screw. So I took a drill and drilled through the screw, but no luck on removing the disc. I've been beating on it for hours now and it's still not coming off. Honestly though, if there's a way to disconnect the e-brake line without pulling off the disc, let me know.
Please help!
1 - 1 of 3 Posts
