Just installed an RV6 Jpipe and high flow pre cats and thought I’d give my two cents. I’m a mechanic by profession so I installed them myself and honestly the install wasn’t too bad, took me about 2.5 hours total and I also did new spark plugs, valve adjustment and valve cover gaskets at the same time. I also had a ZDX throttle body to install but it wouldn’t bolt up to the stock intake manifold.
I’ve driven the car about 100 miles since the install and my feelings are mixed, on the one hand the truck does feel a lot smoother on normal acceleration but on the other hand when I mash the gas there isn’t a very noticeable difference in power. Now to be fair I’m only using my butt dyno AND I probably was expecting more hp/tq gain than I should have. The products themselves are very high quality and everything bolted up beautifully.
