2021 ridgeline rtl 35,000 need advice on tires should i get a lesser tire knowing I don’t drive allot I have the oem stock tires they suited me fine but the cost between oem and Michelin, coopers are light years difference
Until recently I ran Michelins on everything, and when new loved them, but I rotate every 5k on my trucks and never ever got any mileage out of them so I am done with them, glad you are still getting good service out of them,Michelin All Season 80K warranty...what's not to like,.?
I just replaced the OEM tires on my 2023 Ridgeline with the same tires it came with - Bridgestone Duelers - and I'm happy with the decision. Just took it on a road trip, the tires are quiet and I have no complaints. 26+ mpg as well so, all good.How about tires for a Ridgeline that will never see anything more off road than the parking lot at a county fair or some decent gravel roads. in other words, street tires with no pretense of being for off roading?
What are the good ones for the road.
I bought my 2020 ridgeline used with about 15,000 miles. It's got 50,000 on the tires now and I still can't see the tip of Lincoln's head. Falken Pro G5.2021 ridgeline rtl 35,000 need advice on tires should i get a lesser tire knowing I don’t drive allot I have the oem stock tires they suited me fine but the cost between oem and Michelin, coopers are light years difference
Not Michelin please I got 14,000 miles on a set. I’m now running Yokohama on my 2018 RTL2021 ridgeline rtl 35,000 need advice on tires should i get a lesser tire knowing I don’t drive allot I have the oem stock tires they suited me fine but the cost between oem and Michelin, coopers are light years difference
I live in Alberta Canada. I bought Toyo All Weather for my 2019.They have been perfect for City and Highway. I have had travelled some muddy roads and gravel and they performed great. No issues. Will buy them again in about another 20 k which would take it up to 60-70k . Good luck2021 ridgeline rtl 35,000 need advice on tires should i get a lesser tire knowing I don’t drive allot I have the oem stock tires they suited me fine but the cost between oem and Michelin, coopers are light years difference
OEM. They actually look a little small.Did yours rubbed???? Or did you go with OEM size? I also went out in a limb but so far I like them
I too have a 2021 Ridgeline with 35K miles on Firestone Destination tires. I live in central MA and need good traction based on our weather. The Firestone tires performed well but only 4/32 tread left or less and I’m not comfortable going through the winter with them. The knock I have on the tires is low tread life. I rotated every 5K miles and kept the air pressure correct. So, I chose to buy a different brand of tire. I joined Costco so I could get best price possible on Michelin Cross Climate 2 tires. $1000 total not including alignment which I don’t need btw. The Michelins are expensive but I consider tires a critical safety element and the Cross Climate 2 tires have excellent reviews. Plus I’m confident I’ll get 50K miles out of them so not really more expensive in the long run. Hope this helps.2021 ridgeline rtl 35,000 need advice on tires should i get a lesser tire knowing I don’t drive allot I have the oem stock tires they suited me fine but the cost between oem and Michelin, coopers are light years difference
Your Firestone tires had a 60,000 mile warranty, correct? So you got only half life out of them? The original cost for Firestones is approximately $200 each so you should have been credited $100 each under warranty, (using round numbers.) Discount Tire lists CC2s at $1100 for a set of 4. Minus the $400 from your Firestone tires, your new Michelins should have cost you leaving approximately $700. Did I do that math correctly, folks?I too have a 2021 Ridgeline with 35K miles on Firestone Destination tires. The Firestone tires performed well but only 4/32 tread left or less and I’m not comfortable going through the winter with them. I joined Costco so I could get best price possible on Michelin Cross Climate 2 tires. $1000 total not including alignment which I don’t need btw.
One thing to keep in mind is that the OEM Firestones LE2s aren't even the same as the standard LE2s. For one they have the chunky sidewall detail and their compound is almost certainly not the same. I would expect the standard, non OEM LE2s to perform differently and would probably last longer. The mileage warranty for the OEM Firestones may be different as well. . .I too have a 2021 Ridgeline with 35K miles on Firestone Destination tires. I live in central MA and need good traction based on our weather. The Firestone tires performed well but only 4/32 tread left or less and I’m not comfortable going through the winter with them. The knock I have on the tires is low tread life. I rotated every 5K miles and kept the air pressure correct. So, I chose to buy a different brand of tire. I joined Costco so I could get best price possible on Michelin Cross Climate 2 tires. $1000 total not including alignment which I don’t need btw. The Michelins are expensive but I consider tires a critical safety element and the Cross Climate 2 tires have excellent reviews. Plus I’m confident I’ll get 50K miles out of them so not really more expensive in the long run. Hope this helps.
I put a set of Cooper Discoverer AT3-4s on my 2009 RTL in 2023 and think that they are outstanding. Nice ride, very quiet for the tread, good in the rain, even wear pattern, just a great all-around performer. And not for nothing, but they balanced better than any tires I've ever purchased - they needed very little weight and the truck tracks straight through at least 4 rotations.2021 ridgeline rtl 35,000 need advice on tires should i get a lesser tire knowing I don’t drive allot I have the oem stock tires they suited me fine but the cost between oem and Michelin, coopers are light years difference
Had to patch Michelin tire (at least once) on one car, Bridgestone tire on another car.It's funny, I don't know what to think about the OEM Firestones. I like them, but I've had to patch 2 of them from running over junk. Either that's the tire or me, I don't know.. Would the same thing happen with expensive Michelins ?
The reason I'm responding is I'm kind of in the same boat. 40K Miles on my 2023, original tires and I'm looking around. No off road use, unless you consider awful Louisiana roads off road...
Sure the Michelin Defender to max out mileage/cost and if you do not care if you sub-optimize performance, especially in wet or snow. The defender is a hard tire that performs less well in wet and sucks in snow. Get Michelin CC2s if you value safety under wet and snow conditions.Here ya go... get these and don't look back.!!
Defenders do just fine in the snow and wet. They have for years and the newest version is better still. Sure the CC2s will outperform in the snow but not in most other metrics, plus they are absolutely heinous to look at and their rolling resistance is going to give you a small MPG hit.Sure the Michelin Defender to max out mileage/cost and if you do not care if you sub-optimize performance, especially in wet or snow. The defender is a hard tire that performs less well in wet and sucks in snow. Get Michelin CC2s if you value safety under wet and snow conditions.
Install a separate set of studded snow tires in the winter for really extreme conditions.
I cannot comment on Pirellis, etc. because I buy Michelins.
I bought the Goodyear Assurance Weatherready 2 for my 2019 last May. They have performed very well in dry and very wet conditions in Texas. I purchased them based on Tire Rack tests and their comparisons to the Michelin Cross Climate and others. After 5k miles I like the how they perform. They are a big improvement over the OEM Firestone LE2s.Has anyone tried the Goodyear Assurance WeatherReady 2 (latest/second gen)? Guy at a local tire place was recommending them. He said that Goodyear has really improved over the past several years. I had Goodyears on a 2004 Pilot many years ago and couldn't get rid of a vibration. Ever since, I've stayed away. I've typically gone with Michelin or Continental for my cars. The Conti LX25 has been great on our 2019 RDX and I recently put them on my daughters 2021 CX-5 Turbo. My other daughter's 2018 Mazda3 has the Micheline CC2's. They've been very nice on that car, but I needed to buy new 17 inch wheels as the tire size for the stock 18s limited the tire choices quite a bit. The OEM Firestone LE2's on my 2022 RTL-E have started to develop some small dry-rot cracks near the rim. Only 24k miles. Personally, I like the look of the OEM LE2s. No off-road driving for me. Just on-road New England everyday driving. I've spent a lot of time on TireRack so there are definitely a bunch of great options. Considering the Pirelli Scorpion WeatherActive as I'd like the additional all-weather performance. The Conti LX25 is probably my other top choice based on my experience with it. So, if anyone has experience with the GY WeatherReady 2's, I'd appreciate hearing about them -- how you like them and even why you may have opt'd to not get them.
