Up-size to 265/60R18 - Rubbing issues?
3.7K views 2 replies 3 participants last post by  MIke Mercury
Has anyone had issues with rubbing or anything else when going to a 265/60R18 from the OEM size? (No lift kit, no offset, just swapping tires in size only?)
Interested if any specific tires caused a rub or issue in that size. Want to go a little wider and slightly taller in a replacement tire.
Some with aggressive tread I worried might get some rub so before picking a tire, just thought I would seek some wisdom.
If you have not had any issues, what tires with a good warranty, quality ride, and superior wet/snow traction would you recommend based on your experiences?
Thanks in advance....
