Yes, parking lights work. Hazard lights work. But when the stalk goes down, nothing happens. Doesn't click. Doesn't flash on the dash. And turn indicators don't indicate. Push the stalk up and the right side indicators work fine.
If it was a fuse or a relay, wouldn't it affect both sides? Not just the left?
I stopped at an auto parts store to try and find a fuse or a relay, and when the guy heard that one side works and the other doesn't he said that it HAS to be the switch or a wiring issue, and not a fuse or relay.
Any comments on that? And if you still think it's a relay, what would it be labeled as? There's nothing in the fuse boxes labeled for turn indicators. There's one for hazard lights, but again, my hazard lights work fine.
Ok, I found an old post from someone who was having the same problem (Left turn signal doesn't work, right one does) and it was resolved by replacing the relay. So I guess that one side can still work with a bad relay. I also found in that thread where someone posted a diagram showing where the "Turn signal/Hazard relay" is located (and yes, Dimson, it is on the upper right of the interior box). So I'm going to replace that relay and see what happens. Wish I would have gone ahead and bought it while I was at Autozone before. It think it was about $17. I'll let you know soon.
So replacing the relay fixed the problem. That's the good news. Here's what happened.
After buying the relay at an auto parts store for about $20, I brought it home thinking I could just pop the old one out and put the new one in myself. I was able to pretty easily identify the relay, although I could barely see it in the top right corner of the interior fuse/relay box. I could get my fingers on it, barely, but could not get it to budge. After trying everything I could think of, I decided to call my independent mechanic and see if he would do it for me. He said he had a vehicle in his bay, but if I wanted to pull up outside he would come out and take care of it for me. He figured it would just take a minute. Well, about 30 minutes and a bunch of curse words later, he gave up and said if I wanted to bring it back the next day and drop it off, he would tear it apart and get it out. So I decided to go ahead and take it to the dealer the next day, instead. Because I still wasn't certain that the relay would fix the problem, and if it didn't, I'd feel better having the dealership figure it out and have on hand whatever parts might be needed.
So I called the next morning and got a same day appointment. I explained everything to the service writer, including the fact that I had bought the relay at an auto parts store, hoping it would fix the problem, but couldn't get the old one out. To his credit, he went out to my truck and tried to do it himself, but gave up in about 10 minutes with scrapes and blood on his hands. So he put it into service and told me it should take about an hour. An hour and half later, they were done and told me that the new relay fixed the problem. They charged me $68.74, mostly for labor. I paid it and was somewhat happy to do so.
The end. I hope.
