Received and installed my NM tonneau yesterday.
Didn't go through any rains yet, but I'm expecting a leak from under the "cab end" gasket, cuz even if the front rail pushed all the way forward and outer pleather cover literally pressed against the C-pillar panels that hard that I can't insert a piece of thin cardboard between the cover and pillar panels, about 1/4 of the gasket width is still hanging in the air not squeezer between the front rail and plastic bad cover. The gasket is installed all the way forward on the rail, there is no room to move it any more forward.
The portion of the gasket between the front rail and bed cover is squeezed pretty well and I haven't noticed any rail twisting yet.
I'm afraid if a cover is pushed all the way forward the cover's vinyl would rub hard against the pillar panels and wear out the paint.
Also, if the cover is pushed al the way forward, the tailgate is barely covered by the cover.
I've mounter the cover in the position where the front seam/ bulge of the cover is barely touching the C-pillar panels and covers the tailgate pretty well, but about 1/2 of the gasket width is not used.
Q: the kit came with a strip of self adhesive weather foam. Neither instructions or installation video mentioned this strip. What's it for?
And has anyone tried to insert a sheet of hard cardboard or some plastic sheet between the cover and 3 middle rails to reduce "flapping"?
Overall I like the cover, the vinyl looks pretty though and seams are straight and neat, I just wish the front rail was a bit wider with better rail to bed cover seal.
