Hi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
Yup, the best way to haul long lumber! I'ver had one for 25 years. I just hauled 300 bdft of 12' poplar.Easy way is to spend $60 and buy a bed extender - I use mine all the time for carrying lumber. Have tailgate down and strap lumber to front and rear bed tie-down points and to bed extender. Put the standard red flag on the end and you're good to go. Have carried 16 foot lengths this way without issue.
My Bed Extender
My Safety Flag
I hauled an almost exact load with great results: tailgate down; stack lumber tightly, cinch lumber down (may not really do anything but it gave me peace of mind); drive carefully so as not to cause lumber to shift. That’s it. I did strip the tailgate face with painters tape just in case a rock kicked up.....Hi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
I agree with those that indicate you should put the tailgate down and use a red flag. In addition, you will need to use ratchet straps to secure the front part of the load so it stays down otherwise it kick up and slide out of the bed even if the back part is tied down. Remember, the bed is very short.Hi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
I recently hauled 10 2x8x16 PT boards using a bed extender. The extender attaches to the trailer hitch and cost me $55 (less than the $79 delivery charge for the boards and reusable). The extender added a net 3 feet to the bed and tailgate and made the load more stable. I also tied the boards together by screwing a 2x4 to them close to the cab.Hi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
I bought a tow hitch extension that is about 5 ft. long and has an adjustable arm that goes straight up with a crossHi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
Anything past 2 feet of the rear bumper is illegal.I'd lay it flat with tailgate down. Securing it so it doesn't slide around. And put a red flag on the end for other people to see and cover you if you have a state law requiring it. I think that laying it on top of the gate is just asking for it.
Are you kidding? That would be useless with the tailgate up or down. And as I stated before, anything that is more than 2 feet past the rear bumper is illegal. Also, if you block the view of the license plate, that is also illegal.If you can afford it, you want to look into a bed extender that fits into the hitch receiver. Most of them have tie down points on them to secure the load. I have a friend that just used one to haul 16’ pieces with a Nissan Titan. Good luck.
Get a trailer. Anything that is more than 2 feet past the rear bumper is illegal.Hi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
Are you kidding? That would be useless with the tailgate up or down. And as I stated before, anything that is more than 2 feet past the rear bumper is illegal. Also, if you block the view of the license plate, that is also illegal.I have hauled long pieces of material and one thing you need to think about is placing weight on the lumber in the bed to keep from it bouncing up while driving. You can use cement blocks as the weight material just under the back window. Measuring my 2018 bed to the end of tailgate is 7' and you will have 5' sticking out, plus the truck will be lower in the back from the weight.
MLogan
2018 RTL-T
Smyrna, TN
Not helpful. As I stated before, anything that is more than 2 feet past the rear bumper is illegal. Also, if you block the view of the license plate, that is also illegal. Red flags are not a pass. Ask any DOT police officer. Anything outside of legal limits requires a permit. It doesn't matter if it is a POV or commercial vehicle. The law applies to ALL vehicles on public roads.Found these helpful
Allow me to give you more information seeing how there are way too many people giving you bad advice.Hi all. Any suggestions on how to properly haul long lumber (2x8x12). I'll be buying 30 pieces of lumber and need to know if the tailgate should be flat or up? Also, I assume that the weight of this is not problem? Thanks
