Just wanted to give a heads up to anyone needing to tap into the reverse circuit, for a positive 12 volt feed when the ridge is in reverse, for an aftermarket stereo install with backup camera.
The wire to tap is solid green with a factory splice installed, and is located under the drivers side kick panel, in the bundle of wires in there. Just take off the electrical tape and find the solid green wire with the factory splice in it, there is only one. This wire supplies a positive 12 volt signal when the vehicle is in reverse, and 0 volts when in other gears.
