I would like to install turn signals in my mirrors. I would appreciate your opinions positive or negative on this idea. I have looked at the parts manuals for both a 2020 Ridgeline RTL-E and a 2020 Pilot Elite. The Pilot Elite does have turn signals in the mirrors. The parts comparison between the two appear identical with three exceptions. The Pilot has the turn signal lights , a different part number for the upper housing and a different part number for the wiring harness. I’m thinking about ordering the respective turn signal lights for each side and the respective upper housing for each side (the housings are painted to match the same color as the Ridgeline). I’m not going to order the harness because I don’t want to tie into the body control module which may not recognize the new lights or in some way damage the system. Instead I would run the positive wire from each side under the carpet to the module for the trailer wiring harness (which is located behind the rear seat). I would connect to the left and right turn signal wires at the module. This should not create any issues with the body control module. I would ground the negative at an already existing ground point under the dash.
Thank you in advance for your constructive feedback.
