Spooked on 6 speed tranny
5 reading
9.7K views 82 replies 35 participants last post by  Eddiehaskell
Did some research on my '17 RTL-T & though I've not had tranny issues y'all have me spooked. If I were to sell/trade for a more current model btw 2020 & 24 which yr & model should I try to find ? Tks folks
#8 ·
I went from a 2017 to a 2020 and it has been very solid w/ no issues. It does get great MPGs for a vehicle its size (22-24 depending on starts/stops) and is basically the same vehicle being produced today from a practical standpoint. My advice would be to get the best value for your money you can get find as long as its 2020 or newer.
#5 ·
The Modern American way ...
If you want a new RL then get a new one.
If you want a newer RL then get a newer one.
Grandparents Pioneering way is ...
continue to maintain what you've got - and as long as it meets your needs then enjoy it. You can make lots of repairs (if necessary) for the monthly payment price of a newer one.
#9 · (Edited)
Get the least old RL that has the 9 speed tranny that you can afford.
If buying new, from this point on is very good time to get a big discount off a 2025 model, especially when 2026 models hit the showrooms. Shop at the very end of the month and be flexible on colours IE the biggest discounts will apply to RLs they physically have in stock.
Good luck and let us know what you do!
#11 ·
If a trade in and money availability suits and the payment is affordable, the 2025 can be had with up to (but possibly not including) 60 month financing at 0.99% interest through Honda.
#12 · (Edited)
"I'm youngish but I know that vehicles made in the post war era were easier to maintain and more robust than todays offerings which rely heavily on regualr maintenance."
I've really must dispute that assessment. Back then cars required an oil/ filter change every 3K miles; new coolant every 3/4 years. Then there were plugs, points and condensers/ distributor caps; valves re-ground at 50K miles, mufflers every 5 years and rusted thru floorboards within 5-7 years. Yes a backshade mechanic could replace simple components with wrenches and a timing light. I also remember square tires (where they sat overnight - squished, reshaped after driving them a bit). Those white walls went 25-35K miles and suffered frequent blow outs. Drum brakes that easily overheated and created white knuckle experiences. Common fuel mileage of 8-12 mpg.
Todays vehicles are significantly better (and significantly more expensive)- but they are worth it.
#13 ·
I remember annual tune-up with plugs, points & condenser. And then when it was -20 degrees F and the engine got flooded while trying to start it, repeat the plug replacement. I remember changing the oil on my '68 Mercury 390 cubic inch engine and setting the used oil in a closed container outside the garage, and the oil turned into a semi-solid sludge at -20 degrees F.
#26 ·
Totally agree that newer vehicles are more efficient and require less maintenance. The downside reality is that when a new vehicle requires service it will be very expensive and most likely require special diagnostic tools. For example my ‘21 RTL-E Honda Sense cam failed. This camera is a $1200 part and requires another $800 in labor to install and calibrate.
#20 ·
I stay current and as modern as my finances allow on everything from phones to vehicles as I am only riding this life out 1 time here on the big blue ball
Sure I could still be driving my old 2007 GMC truck but would that be fun? exciting? enjoyable? stress free? low maintenance? nice to look at?
Big ol fat "No"
Im enjoying the ride while im here with-in my budget
#83 ·
Well gosh I can see this perspective too. I do have some people in my family that chased max money all their life and drove 20 year old vehicles...they say they're completely satisfied with them, but sometimes I wonder if not "losing" money can kinda become an unhealthy obsession (especially when you have more than you can realistically spend).
#24 ·
I was whining about something with my car the other day, and my wife said "Just get a new one". I wouldn't want a new one.
The sales tax alone on a new $50,000 car is $4125 (8.25% in CA). Add depreciation and you're a lot of the way towards the cost of a new transmission.
I imagine with my 2019 RTL-E, I'm going to start seeing costly electronics fail and that will be the catalyst for replacement. The radio has failed in every Honda I've owned, but luckily those were the days of the easy Radio Shack replacement. I don't know what happens when the Ridgeline Infotainment system goes.
On-topic, If I was scared of the transmission failing I'd probably be looking for the version with the bed speakers, before the auto start/stop, 2020+.
#49 ·
Yikes, I can't imagine paying over $4k in taxes. In SC, sales tax on new vehicles is capped at $500 which was $300 until a few years ago. We do however have personal property tax on vehicles here which is probably a little higher than your vehicle license fee. I guess the state is going to get theirs one way or another.
#31 ·
Check out new - and consider extended warranty. I went through the same exercise for same reason 10 months/10,000 miles ago and don’t regret at all. Improved hood, paddle shifters, ZF transmission, locking tailgate, TrailSport pkg, new styling, wider opening rear door - and hasn’t been back to dealership for any warranty issues. I do tow trailers so the warranty gives me a lot of peace of mind that was lacking with a 2018 RTL-E. I thought my dealer gave me a good number on the trade so you might be surprised too and get to choose between a ‘25 or ‘26. Good luck!
#32 · (Edited)
One little known factor which is important to me and probably some others--2017-19 can be placed into neutral from inside the cab if the battery is dead, which has been the norm. I think starting in 2020, you need a special tool and know how to use it, and most important--you need access to get at the spot where you use the tool. I don't know all the details, but when I park in the garage I don't have access to the front end. When my battery died in the garage, I was able to release the transmission lock and shift to neutral, then push the truck back until I could open the hood and replace the battery. I think on a 2020 or after, I'd need a tow truck to drag my truck, skidding all the way, back far enough to open the hood.
And I happen to think the 2017-19 looks a lot better, but more importantly, with the newer front end I've read that it is more difficult to know where the front end is so parking is a bit harder.
#34 ·
One little known factor which is important to me and probably some others--2017-19 can be placed into neutral from inside the cab if the battery is dead, which has been the norm. I think starting in 2020, you need a special tool and know how to use it, and most important--you need access to get at the spot where you use the tool. I don't know all the details, but when I park in the garage I don't have access to the front end. When my battery died in the garage, I was able to release the transmission lock and shift to neutral, then push the truck back until I could open the hood and replace the transmission. I think on a 2020 or after, I'd need a tow truck to drag my truck, skidding all the way, back far enough to open the hood.
We have info here on how to make a "homemade" tool to put the trans in neutral with a non running engine.
I will see if I can find the thread and post it soon.
#44 ·
It's all in what you want. I have a 2019 RTL and my wife has a 2020 Pilot, both with the 6 speed. I'm right at 80K and hers is at 90K; she mainly does city driving with the occasional long trip. Mine is about evenly split between country driving and towing a 4K pound trailer on the interstate. The only problems so far have been a leaky windshield and prematurely worn out sway bar mounts. I change the transmission fluid and filter myself every 20K miles regardless what the MM says. So far we love them, especially since they're paid for.
#45 ·
Read everyones posts regarding being spooked on 6 speed transmission. Decided to stand pat & do drain & fill more often. Don't like push button shift-- thought that ended with Studebaker ! Don't like Giant Ridgeline on tailgate. Trying to look like Ford/Chevy I suppose. Tks for your inputs folks & good luck. Ridgeline is a good truck !
#46 ·
A lot of nice 23's out there with nice depreciation and no Giant Ridgeline on the tailgate.
The 23's had a long production run since the 24's were not available until about Dec 23/Jan 24.
There are a lot of 23's out there.
You are in a sweet spot for a 23.....not too old......not too new.....and a CPO unit would have great coverage.
