Lovely.
Another nitrogen discussion.
The facts
Air is 78% nitrogen.
The volume inside a Ridgeline tire is about 2 cubic feet.
The recommended tire pressure is 35 PSI or 2.38 ATM.
The math
+ 1 ATM static = 3.38 ATM
* 2 cubic feet = 6.76 cubic feet
The results
If a tire that leaves the factory filled with air which contains 78% nitrogen is completely deflated then reinflated with 4.76 cubic feet of pure nitrogen to achieve a pressure of 32 PSI, you end up with 93% nitrogen - only 15% more nitrogen than regular air.
Assuming a dealer who installs green caps and/or charges you for nitrogen actually inflates the tires with nitrogen (sometimes they
say they do, but they actually don't and you'll never know unless you have the air analyzed), they're only going to deflate and inflate once for 93% nitrogen purity
at best.
At a price of $71 for a size 300 cylinder of industrial-grade nitrogen, it costs a dealer about $1 to completely reinflate a tire with nitrogen - that's half the MSRP of a Honda valve stem cap.
The factory, gray plastic caps are good quality and they have O-rings, but they list for $2 each.
