Where do folks get their oil drain o-rings ?
8.9K views 55 replies 21 participants last post by  911medic
For V6 2018.
I would like to know of a commercial source that matches OEM. Last time I found a 4-pack of rings that all look different. Used the aluminum crush washer out of the four and don't trust the others.
Just sayin', love my Ridgeline, but oil changes have been kind of a hassle.
Thanks
#3 ·
#42 ·
#13 ·
We just installed F106SX valves on our new Hybrid CR-V's. All our Passports, Ridgelines, Accords, Civics also use same. No tools, no crush washers and easy to remove once traded in or sold. Never had an issue with leak or valve failure.
Fun fact:.. put a EZ-124 into our chipper and EZ-109 into our new Honda EU7000ISNAN generator.
416322
#19 ·
Guess it’s an uninformed upbringing on motorcycles and never having an issue as I learned to wrench on things. I just don’t bother.
There’s a long history of the results of not changing oil. Can’t say I’ve experienced or read of any catastrophic failures due to oil crush washer neglect.
It’s also a nice way of conveying to the OP that there’s more important things to worry about.
#40 ·
As with most arguments like this (e g. - oil threads), the truth generally lies somewhere in the middle, if there is a truth. Some folks need definitive answers, and more power to them. I learned long ago that life is too short to worry about lesser definitive.
Switching gears, I got a Yard Machines (MTD) push mower back in 1998. It had a 6.75hp B&S engine, with no oil filter. Changed the oil once a year, used the dog out of it in Texas for six years, then it moved with me up north. Kept using the heck out of it until about seven years ago, then gave it to a co-worker. He's still using it.
#43 ·
My local dealer will change oil for about the same cost as doing it myself. I think they see oil changes as a loss leader - they know if they get you in the shop they can sell other services. That’s why some dealers offer “free oil changes for life”. One day I’ll probably go that way, but for now I enjoy performing oil changes as well as other maintenance tasks.
#47 ·
I've got a bag full of the oil pan washers that I got for cheap, probably from HandA when they were still in business. It was likely an add-on to an A01 filter order (should've ordered several cases of those when they were available!). Anyways, the bag of washers has a designated spot on a garage shelf, so they are quick and easy to find when the time comes. No fuss, no muss, no worries.
Will be checking out bulk washer prices on trans (I've the 6AT) and diff plugs, too. I can always use them for other stuff.
