does anyone have tips or any idea how to mount these big guys in the same locations? im thinking i may have to just drill them into the grille cover for the stock speakers. A professional mounting kit would be nice. thanks
3500 MAX POWER.... So actual power per how ever many channels the amp is is wayyyyy lower...If the OP truly has a 3,500 watt amplifier, none of this will matter, anyway. That much power will instantly destroy a 6x9" speaker or any other size that can be mounted in a vehicle's door. That's more total power than many movie theaters use to fill tens of thousands of cubic feet with bone-jarring sound levels. The interior of a vehicle is only a few hundred cubic feet.
The RTL w/ nav has the four door speakers, a set of tweeters in the dash and the stock 8" sub behind the passenger seat. I'm not for certain on this, but I would certainly venture a guess that there is at least some equalizing and filtering that is done within the stock head unit. The sub is probably passed at somewhere around 80-100hz and the tweeters have a passive crossover built in to them that filter out the lower frequencies that could be harmful to them. I haven't had the stock head unit in so long that I don't remember is there is an option to turn off the subwoofer. If there is, that usually sends a full range signal to the door speakers.is the RTS w/ nav screen full range front and rear?
Yes, the subwoofer turns "off" when adjusted one "click" below the lowest setting. Full range frequencies are always sent to the door speakers regardless of whether the subwoofer is on or off or what level it is adjusted to. In other words, turning on the subwoofer does not cut low frequencies from the doors speakers. The head unit does have a low-pass filter on the subwoofer output. Bonus information: The subwoofer output is a summed and low-pass filtered version of the rear speakers. If you fade all the way to the front speakers, the subwoofer output goes to zero.The RTL w/ nav has the four door speakers, a set of tweeters in the dash and the stock 8" sub behind the passenger seat. I'm not for certain on this, but I would certainly venture a guess that there is at least some equalizing and filtering that is done within the stock head unit. The sub is probably passed at somewhere around 80-100hz and the tweeters have a passive crossover built in to them that filter out the lower frequencies that could be harmful to them. I haven't had the stock head unit in so long that I don't remember is there is an option to turn off the subwoofer. If there is, that usually sends a full range signal to the door speakers.
