Has anyone mounted an electronic brake controller in their Ridgeline? If so, which one did you buy and where did you mount it?
Bob
Bob
I measured the interior light switch (to the left of the climate controls) and it's exactly the same size as the others we are talking about, despite its three-way function. If you didn't want to drill into your dash, you could move the interior light switch to the lower-left blank and install your brake controller in the original interior light switch position. That would make the controller fall "easy to hand" for right-handed people; which would make dealing with braking emergencies or sway issues easier to address without having to change your view of the road....I did notice that there is a nice piece of vacant real estate immediately to the left of the interior/door light switch. And it is visible from my driving position. So I might explore that possibility. ...
Very good idea. I will try this. Thanks!I installed mine with a disconnect and when it is used I velcro it on the panel under the steering column.
I hear you. I was sweating bullets when I tapped into the lock wiring for my pop and lock installation. Thanks for the pictures, it's a good looking install.Oh, and the hole that will haunt me forever from the first attempt....
