21 - 40 of 136 Posts
I believe it's preferable to hear a little ticking rather than no ticking at all.
Most definitely. I would not rely on how it sounds unless it does not sound normal or like something has really come loose. If you can't hear them when standing near the front you may well have a problem.
Discussion starter · #23 ·
There are different kinds of "ticking" sounds. Often, it's a fuel injector that's making that noise. You'd need a mechanics stethoscope to help zero in on that sound. That's how I found out my tensioner was making noise when my AC was kicking on (when my mechanic friend was sure it was the AC clutch!).
FYI, I suppose you could pull off each injector wire one at a time and see if the sound goes away. Just a thought.
Reactions: zxhoya
Another reason to check the valve clearances:
http://honda-tech.com/showthread.php?t=2725031
Yep. I've decided I'm definitely going to do this within the next few months. I'm at 137k miles now and my truck has a vibration at idle while in Drive that goes away when I press the accelerator. I am pretty certain my valve clearances are off. My wife's Accord now has 150k miles and is still extremely smooth with no vibration. Being that we're likely trading that one in within the year, we aren't touching it. The truck - we'll have it at least 3 more years. Just want to make sure it's going to make it that far. I'm going to start calling around to different dealerships soon to see who can do it for the best price - just like I did for the timing belt service. I know it's a pretty time-consuming job and I really don't want to get into it myself. If a trained Honda tech can do it faster than I can for $300 or so, I'll be more than happy to pay for that.
Did my valves on sunday at just shy of 154k. On cold starts it idled really rough and had a little stumble and while stopped at lights it idled very rough. So picked up two valve cover gaskets and one intake gasket and went to town. all my exhausts were pretty much closed except a couple had a small bit of movement and all my intakes were about .004 loose. Got all my intakes to a tight .009 and my exhausts to a snug .0012 and it purrrrrrs like a kitten now. Plan about 4 hrs if it isnt your first rodeo and about 6 if it is. Double check all your clearances and all the 10mm adjuster nuts for tightness after manually cycling the motor 2 times.
Thanks for the perspective & advise. I have not done mine yet, but am starting to get a little rougher idle than previous. Not bad, but I can feel it coming (135K miles), so I'll be getting around to it probably before year's end.
So what is the intake gasket for? I don't recall reading about anything other than the usual valve covers & engine cover being removed for this job.
It says a lot when a fair number of people post about getting a valve adjustment, or they are concerned about a ticking sound, etc. and they have well over 120,000 miles on their trucks.
There seems to be very few major issues reported. I suspect this is not typical for many auto forums. Would I trade a little worse mpg for long term peace of mind? I would and I do.
The gaskets that sit under the intake manifold. How it is is...motor/gasket/intake riser block/gasket/intake manifold. They are metal gaskets and I never reuse metal gaskets. But since you don't have to remove the intake riser. You only really need to replace one. You remove the intake manifold to get access to the rear bank of cylinders.
Dnick. It is a lot easier then you think. I didn't remove any of the coolant lines all I did is exactly what the second link shows you. Just pull the manifold as far as you can straight up off the studs and stand it up on the throttle body. Or an even easier way which I will do in the future is remove the throttle body with the four 14 mm nuts and just pull the intake manifold off completely. Just need to buy a couple buck throttle body gasket. It is a lot easier then you think, just time consuming to pay attention to what you are doing and check your work twice. If it was rear wheel drive v6 not a sidewinder set up then you usually don't remove the intake manifolds.
Thanks for sharing the tips/experience.
I just finished my first valve adjustment today on my 07 Ridgeline with 165,000 miles. The intakes were all fine, but the exhaust valves were way tight. It fixed my rough idle, and no more fault codes (yet).
Just a few thoughts on the job:
1) It took me about 6 hours start to finish, with several interruptions and some time looking for lost tools.
2) Those rear exhaust valves are a royal PITA! I wanted to rip out that stupid wiring harness! Getting the feeler gauges in place normal to the valve stem was difficult for several of them. Angled gauges (~$8 on eBay) will make the job a little bit easier.
3) Use a torque wrench. The torque specs for everything are pretty light. Without it I would have surely over-torqued everything by nearly double.
4) Don't forget to remove the rags from the intake manifold! I had the manifold cover in place but not torqued before I realized I forgot something.
5) Buy the intake gaskets and valve cover gaskets, not the valve cover gasket kit. Don't replace the spark plug tube seals or the head cover washers unless they are damaged. It's just not worth the hassle. Also, note that the valve cover gaskets are sold individually.
I just did the valve adjustment today. I have 165k miles and had code p0175 which would come back almost immediately after I cleared it. It was idling rough and stumbling from a stop. The job took about 6 hours. Angled feeler gauges are really a must for this job. I replaced the valve cover gaskets and the intake top cover and spacer gaskets. Instead of stuffing towels into the ports, I removed the top spacer gasket, put a few strips of duct tape on it, then cut out the two holes for the studs and replaced it. It's a little safer than towels, and I am really good at dropping things into bad places. I used a line clamp ($15 bucks for a set) to close off the coolant lines and pulled the intake with the throttle body in place. After the job was done the truck idled extremely smooth and I have no stumbling or hesitation. Also, no code so far. Very nice to have pictures to refer to when doing a job like this. A top side creeper would have made it a lot easier to get to the rear exhaust valves. Then again, so would losing a hundred pounds. Guess I'll get the creeper next time.
Nice job! :act030:
Thanks for great info! My ridge is having trouble with cylinder 6 misfire. I've changed spark plugs, ingnition coils, and no change. Next I will clean EGR valve: if no change, I think I'm gonna try this valve adjustment.
I was wondering if anyone can give me parts numbers for gasket etc that I should have? I even don't know what angled feeler is: if anyone can tell me what it is and where to find the tool I would appreciate it a LOT! Thank you!
'06 ridge RTL w Navi 150,000miles
Prior to the valve adjustment I was averaging 14.7-16.5 mpg. After the valve adjustment, I've only filled three times so far, I've gotten 18.3, 18.3, and 18.1.
ZowieK, you need:
Valve cover gaskets (Honda calls it a head cover gasket) Part #12341-RCA-A01. They are sold individually, so you'll need 2.
Intake manifold gasket Part #17105-RCA-A01. I only changed the top one, but there is a second identical one under the intake riser. You don't have to remove the riser, but it unbolts with the manifold.
Intake Manifold Cover Gasket Part #17146-RJE-A01
This is the angled feeler gauge set that I bought:
If I were to do the job again, I would invest in or try to borrow a topside creeper, which I had never heard of before this. Also, make sure to use torque wrenches and follow the proper torque patterns. Good luck!
