61 - 80 of 136 Posts
I strongly encourage having the valves adjusted when the TB/wp service is done. The exhaust valves tend to wear into the seats which tightens the lash. Over time, that could lead to expensive issues and if you plan to keep your RL for the long term, it's my opinion that the valve adjustment service is well worth the investment.
Also, consider having the radiator replaced as a preventative measure to prevent the SMOD issue. Rock auto has a Denso radiator with an upgraded design which seems to eliminate the faulty design of the OEM radiator. Good time for a coolant change anyway.
Reactions: Carsmak
just dropped my '06 off at dealer for water pump, timing belt, etc..and tune up........they want to do valve adjustment ($500)...100,000 highway miles....pull the trigger or hold off?
They want $500 just for the valve adjustment?? That's ludicrous. I had my local dealership do my adjustment as a one-off service (not in conjunction with the TB service) and it ran me $350. If they're doing the timing belt, they will already have a few parts off that need to come off to get to the valves. It's entirely labor and it is NOT a 5 hour booked job.
That being said, it is a good idea to have the valves adjusted if you plan to keep the truck for awhile longer. If you're having the TB service done, I assume that's the case.
1) If they are doing a Timing Belt replacement then you might as get that inspected. But it hard to know how deep another mans pocket is.
"The average cost for a Honda Ridgeline Valve Adjustment is between $353 and $469. Labor costs are estimated between $264 and $333 while parts (cover gaskets and seals) are priced between $89 and $136. Estimate does not include taxes and fees."
2) If you are going to do the valve adjustment, Did they ask you to leave your vehicle with them overnight? The answer to that question will tell me a lot about that shop.
Reactions: Carsmak
^^ The only parts necessary for the valve adjustment are the valve cover gaskets that are $20 each. Many on here will say that you can easily re-use the old gaskets without issue, but if you're going through all the trouble to get the covers off, just replace the gaskets. My bill came out to 3 hours of labor ($315), two gaskets ($40), plus taxes and minus a 10% off coupon for a total of $350.
As stated, this service MUST be done when the engine is dead cold. If a shop tells you to drop it off in the morning and they'll have it done by the end of the day, run the other direction. The truck should sit for a minimum of 8-10 hours or so for it to truly be "cold".
Reactions: Carsmak
Exactly, It should be done on a dead cold engine, anything else is a waste of time and money...
Unfortunately, Prices on such service vary widely, and although "HIGH" I'd put $500 on the very top of the scale, locally it's priced about $450, it I'm willing to drive an hr and leave it overnight, I could easily find $350
With the timing belt service a valve adjustment should only be an hour, two tops, of experienced labor. Theyll already be replacibg the plenum and valve cover gaskets if theyre doing it by the book anyway so it should realistically only be about 100-200 more tops.
Actually, the spec from the FSM is for the engine to be less than 100*F for the valve adjustment. Not dead cold (which is a relative term anyway).
Depending on the ambient temperature, my truck does stay warm for quite awhile. There's no way it's under 100 degrees after even six or eight hours. Case in point for dropping off the truck at night and letting the techs do the service the next day. Any shop that will say it's "fine" to drop off in the morning and then do the service 3-4 hours later isn't doing it right.
Reactions: Carsmak
Hey everyone, I picked up an 08 Ridgeline about three weeks ago and had a bit of cold rough idle and MPG in the 15 range. Decided the with 147k the valves may never have been adjusted. Started the job yesterday and every exhaust valve but one was tight. Five cylinders had one valve that was VERY tight. To the point of just a few thousandths clearance on a few. Intakes were all close but a touch loose. Funny thing is, the really tight exhaust valves were all on the same side of the cylinder. I'm at the point of getting the intake manifold back on. I replaced all the seals. Probably could have left the spark plug well seals alone those plus the cover bolt seals cost an extra hour of time. I'm 4.5 hours in with about an hour of buttoning up left. I went once all the way around and double checked clearances. Triple checked every adjuster nut.
I'll button it up this evening and see how it runs. Started way too late yesterday evening. I did the tear down and front bank on Monday evening for 1.5 hrs and the spent a little less than 2.5 hrs last night doing the rear bank (hadn't taken the rear cover off yet) and rechecked the front clearances while I was at it. Futzing with the gaskets and seals and cleaning the valve covers took about an hour.
Got it all buttoned up this evening, started up and I could tell immediately it was much smoother at idle. Let it warm up for a couple minutes and checked for noises. All good!! Went for a 10 minute drive an could hear a muted popping sound. Popped the hood and it was one vacuum line that I didn't connect(Bottom of Evap purge valve). Put it back it on, problem solved. Went for another drive and noticed better bottom end response, super smooth idle and more power at higher RPM too.
HUGE improvement in driveability and smoothness. I'm sure my 15.1 MPG will improve as well. Now on to all fluids, new speakers, some motor mounts and a couple suspension bushings next week.
The coming week my 1990 Volvo 240 project gets a bit more attention.
^^ That is pretty much exactly what I encountered when I did mine a few years back. Most of the exhaust valves were tight with two being in spec. Five of the six intake valves were fine with one being a bit loose. It wasn't a huge difference, but the smoother idle, better low-end performance and better top end pull were certainly noticeable. I didn't see much in the way of fuel economy improvement, but that's honestly on the lower end of my concerns with how little I drive.
Just did mine this morning at 155k. All but 2 exhaust valves were tight, all intakes good.
Added 20% Marvel oil to crank case and 12oz to tank of 93 for the valve seats. Once this tank is done doing high mileage oil change and half bottle of Liqui Molly for the next two oil changes.
Hi guys,
PREFACE: If your truck has over 100,000 miles and you are experiencing a check engine light--and your codes are emission-related--they can often be triggered by this common Ridgeline issue of the exhaust valves being too tight (zero to neg lash).
After reading bits and pieces on the web of doing a valve adjustment on all kinds of other Honda V6 engines, I decided to go for it and tackle the job myself. If you haven't done a spark plug change yet, you'll want to do it at the same time. Don't scrimp on plugs, get the original part for these. UPDATE 3/18: Torque settings and other useful info on tackling this job can be found here.
Here are some tips that might help you should you decide to do it yourself, including this master image that will help guide you through the nuts and bolts of it (sorry, couldn't resist):
1. You will need, at the very least, (2) two replacement valve cover gaskets. These gaskets are different than the original, superseding the ones that came on the car. They are thinner. I prefer the original design, but for whatever reason, Honda changed it. You can use your original gaskets if you're feeling gutsy, but I opted to change these.
2. Yes, the intake manifold has to come off. I left the throttle body attached to the manifold and disconnected all the wires and hoses going to it. The top plate has to come off to gain access to the bolts that hold the manifold to the head. Use napkins shop towels to plug the intake ports!! Do not leave these uncovered--a nut dropped into one of these holes will certainly ruin your day (and possible warrant a full head removal).
STOP what you are doing now and plug these intake ports before continuing any further! Do it!
3. The injector wire harness and guides do NOT have to be removed, you just have to wiggle the valve covers a bit to get them out (rear). There are two 10mm head bolts holding the back plastic wire cage, the one on the left is hiding a bit. There is also a bracket behind that back left bolt that holds a hose to the valve cover, remove both.
4. The front valve cover is as easy as pie. You don't even need to take the manifold off to get it off...it's the rear valve cover that causes extra effort. One of the valve cover bolts is hiding behind the plastic wire cage, as shown below.
Other hoses and brackets that need to be disconnected:
Just finished 2011 with 100k. The hardest part is getting t he rear cover off. All the valves were about .004 loose, Rock auto has intake gaskets for under $20. Used those and comes with throttle body gasket. unbolted it and its way out the way. Left wires and hoses on it. Write up gave me the courage to do it. About 5 hours. Two was getting rear cover off.
Hey guys,
I've read through this thread and didn't see, which way due you turn the crank to find TDC? Clockwise?
Thanks!
There are some helpful videos on YouTube that would be good to watch. When facing then engine from the right side, normal rotation is clockwise. It's best to turn in that direction, but if you overshoot a position I think it can be okay to go backwards (someone can correct me if I'm wrong). The biggest concern with going backwards is the bolt loosening when you use it to rotate the motor, which is not a concern with clockwise rotation. With the spark plugs out, the engine is easier to turn.
