41 - 60 of 63 Posts
Discussion starter · #41 ·
Hi, just joined the group after purchasing my 2012 RL sport, just curious, will the 2013 mdx 3.7 swap in without issues? It’s rated at 300 hp so that would be a nice improvement.
Hello and welcome! There are couple members on here who attempted this swap before me and they used the dual VTEC J37A engines on their 2009+ RLs. It was because of their thread that I attempted this swap, so I think you should be good.
No issues on my RL. I've put about 2K miles on it after the swap and it still sounds very solid. Going to do some interior mods when I get a chance. Performance will have to come later:sneaky:
The j37 is a direct replacement for the j35 with very few changes. I put a j37a1 in my 05 rl. while still using my j35 computer
Nice!!! If you could upload some pictures of what your engine bay looks like that would be awesome!
I know its been almost a month, but dont expect anything earth shattering. Physically, to the untrained eye, the J37 and J35 look almost identical.
Yeah I guess I'm just looking for more proof of concept from more sources then expecting it to look any different 🤣
This is an A4, but you get the picture.
Been hijacking another engine swap thread for a bit and thought I start my own so here I am.
Disclaimer: I’m not a mechanic, just a dude who likes to work on cars. Learn as I go kind of DIYer. So please take everything I say or suggest with a grain of salt. Please do your own research before attempting an engine swap. I’m not responsible for damages done to your vehicle.
Engine: J37A1
Donor: 2008 Acura MDX with about 200K kilometers.
Recipient: 2007 Honda Ridgeline with 340K km
Reason for swap: Noob mistake forgot to tighten camshaft bolt after changing seal. o_O Timing belt jumped and valves kissed the pistons.
The J37A1 is very identical to the J35. Almost everything fits like factory aside from some minor mods.
The J37A1:
Im gonna get right into it. Like I mentioned earlier, the J37A1 is identical to the J35. It will perfectly mate with the RL transmission without any mods. You just have to use the J35 flywheel. engine mount positions, valve covers, pulleys etc...everything fits like a glove.
Even though the MDX manifold is lite and made out of magnesium, I opted for the RL manifold simply because of the ease of direct swap and not have to drill holes for additional sensors or worry about intake fitment issues/clearance. Also, unlike the 2010+ MDXs with larger IM/T-body opening, the J37A1s from early MDX has the same throttle body diameter as the Ridgelines J35.
The thermostat housing of the RL has an sensor.
The VTEC solenoid oil sensor also needs to be swapped out from the J37 as it is different from the J35.
While I had the engine out I replaced all the seals with OE Honda. This includes the rear main, crank seal, oil pump O rings, camshaft seals and rings, and valve cover gaskets. I also resealed the oil pan and pump with Hondabond.
Replaced the timing components with Aisin timing belt water pump kit:
Again the flywheel of the J37 WILL NOT bolt into the torque converter of the Ridgeline transmission. You have to reuse the flywheel from the RL.
Lastly, the fuel injector harness from the Ridgeline WILL NOT fit the J37 injectors. You will have to de-pin and swap them out. There are YouTube videos that show you how to de-pin generic Honda injector harnesses.
Aside from the above mentioned, everything else is pretty much cut and paste from the J35 to the J37.
Here is the J37 engine ready to be dropped into the RL.
I forgot to mention that the manifold stud is shorter on the J37 and so I had to replace them with the ones from the J35.
I’ll admit...the engine needs a deep cleaning. This was a one man side project without an indoor garage...I just want to get it finished and running before harsh weather hit. Not looking for any other performance mods at this time. Hopefully this thing will last me another 150k km or so.
Thanks to all the forum lurkers and gurus that offered support and advice. Please feel free to post any questions or comments.
Long story short my 2011 RL detonated. I bought a replacement engine. Which I assumed was a J35 because that is the engine advertised.
After much frustration, (I cannot emphasize much frustration enough.) And about $9k. I read this thread and suddenly everything became clear. I now have a 300hp 2011 Honda Ridgeline.
Discussion starter · #48 ·
Nice! Congrats and welcome to the club my dude 👍
congrats on the replacement, despite the frustration.
Since the PCM controlling the fueling and the grade of fuel you use is different than of the Acura cousins, you can be assured that you are not looking at a 300hp Ridgeline.
I just got doing my swap 3.7a1 into my 06 Ridgeline. Came out an 09 mdx. I’ve got pics and f the steps also have pics of the all of the parts need swapped out. Just putting my 2cents in. This was actually cheaper than the stock engine
Discussion starter · #53 ·
Great job! I have put approx 28k miles on the engine since the swap and it is still going strong. These J37s are pretty reliable for an all aluminium block. Hopefully you can dyno/tune yours so we can gather some performance specs post swap. I've just been dailying mine for the past few years and focusing on other projects. Cheers👍
You rock and thank you for documenting it as you go along.
The J37A1, as mentioned, is from the '07-'13 MDX which is a Gen 2 MDX.
'07-'09 MDX were similar to the '06-'08 Ridgeline, and the '10-'13 MDX/ZDX were similar to the '09+ Ridgeline. The ZDX did use the J37A5 variation and used the 80mm throttle body.
These engines were similar to the J32A3s found in the Gen 3 Acura TL ('04-'08). It is also similar to the J35A6 found in the '05 & '06 Odyssey ('08-'10 had different bellhousing). Also similar to the J35A8 from the '05-'08 Acura RL and the '07-'08 Acura TL Type-S. Great choices of engines if one really sits down and does a lot of homework, and a lot of these engines are dirt cheap to buy and next to nothing to install at home.
I commend you for it and cant wait to see some pictures and your first hand accounts of driving it.
BTW, looking at the pictures of the J37 valve cover, I presume it is not the painted one but the raw metal one?
What about an engine out of a 09-10 Acura RL into a 07 Ridgeline?
I was able to coax some information out of the local JDM guy about the J35A engine I purchased
He says that it would be difficult to find out exactly what HP this engine will have once installed on my 2007 Ridgeline, but he reckons that with using 93 octane fuel, I should be looking at around 270 HP with the stock ECU. It appears that it is the ECU that would keep me from seeing the full HP at 286 (the HP rating as mentioned in the Wiki information regarding the J35A engine).
I do wonder if adding a larger throttle body or better intake manifold or anything else might help compensate for the stock ECU?
On the contrary, it would be easy to find out once you install it - you just take it to a dyno and do a dyno run.
Lack of version types in the JDM engines make it a bit more difficult because the J35 could be from '99, or could be from '05. Because of that, it could be the engine that came from a Honda Legend making 296hp or an Inspire variant with 250hp.
And there is no other way to distinguish the two other than a dyno test?
Perhaps a picture of the piston top?
I assume the 250 HP version has lower compression.
Here is a picture of the top of the piston. Looks like 11.0:1 lol !
41 - 60 of 63 Posts
