finally got around to installing my new radiator was really easy.
take the top plastic piece off:
take the bottom shield off:
take off this hose that goes to the rad, at the transmission (the one on the shiny pipe):
take off this hose, have the catch can ready for both hoses:
drain the radiator (i used the petcock), take off the radiator hoses, top mounts, hood prop holder, fan wiring, don't forget the one for the a/c
ta-daa:
transfer fans and trans hoses to new radiator, (don't forget to tighten the tranny fittings after getting them in the right direction):
reinstall everything, refill with coolant and tranny fluid (started dw-1 swap), bleed air and you're done.
i realized i should have bought the foam pieces for the top and bottom, but ended up cutting the old top one off and used some 3m tape to stick it back on the new radiator. i've read report of the new units being loose, and i think this was the problem, i have almost no movement
temp seemed to be a bit higher than the old unit, but there might have been some air still left in there, temp is better today
and that's it, i still have the lower shield off checking for leaks.
here's the old fittings, not much rust, i could have gone longer, but i don't like to gamble with expensive parts like transmissions...
ta-daa:
