Re: 1st Oil Change Synthetic Not Used??
Wow, so much stuff going on in just one thread!!!
1. Honda no longer has a synthetic blend. It's all synthetic now.
2. I don't know of a dealership that uses Honda-branded oil for oil changes.
Someone else mentioned it, maybe you, but there are two "full synthetic" oils in 0w-20 from Honda. Dealership I work at only uses the "Ultimate Full Synthetic" in 0w-20.
1. Oil changes have become loss leaders to get people into dealerships where they have the opportunity to upsell other services (tires, filters, brakes, batteries, fluids, etc.)...
Very true. Due to the tight margins on most cars and even smaller SUVs, dealerships can't survive on new sales alone, so they HAVE to form lasting service relationships with customers.
As a comparison, my local VW dealer charged me $100 for an oil change to my previous Passat. They also charge significantly more on other services than Honda dealer does.
OUCH!
It says on the invoice they used qty5 of a part# 127075 description 0W20. Wonder if that 127075 is the Honda part number for their official oil.
Not a Honda part number, as far as I can tell. Could be a partial number, but not likely. Maybe it's a job code/sku?
I talked with Honda today and they advised that Honda doesn’t have a full synthetic oil and Honda recommends their synthetic blend in all of their newer vehicles.
Already covered, but just to reinforce this. Honda actually has 2 full synthetic oils in 0w-20. As I understand it (could be wrong, can't find the link) the ultimate full syn is 100% PAO (group IV?) synthetic.
There are no "conventional" 0w-20 or 5w20 these are group 3 oils.
"synthetic oil" is a widely defined term most often what this means is a group 3 or sometimes called Group3+ hydro cracked oils then they are aren't fully man made but are labeled synthetic or fully synthetic by some but truly aren't. Additionally the fischer tropsch refinement also called GTL or gas to liquid seems to be a "3+" this is also available in varying % as a blend Pennzoil platinum was the first guys to tout this I can recall.
These group 3 oils are often blended with group 4 to offer very high or ""extended protection blends like 15K
A Group 4's or manmade PAO formulation are synthesized differently and considered the top ranking of what definable as synthetic. . Oils like Mobil ones annual protection (20K) have a very high percent of PAO in them but are still blended with group 3+.
If someone says fully synthetic they should be able to answer how much PAO in the blend. ...
man wouldn't THAT be some truth in advertising!
UPDATE: It appears there are currently two different part numbers for Honda full synthetic 0W-20 oil - 08798-9037 (silver bottle labeled "ultimate") and 08798-9063 (black bottle not labeled "ultimate") - the latter of which appears newer. The 08798-9037 is/was made by Phillips 66 for Honda. I can't find an MSDS or any information verifying whether or not Phillips 66 still makes the 08798-9063. It's possible Honda changed suppliers...again.
As far as I can tell, the "full synthetic" is supposed to now take the place of the syn-blend. Less expensive than the "ultimate" but still good oil. I suspect it may not be rated for the newer 0w20 turbos, but can't get an answer on that. My dealership only use the Ultimate full syn in 0w20, so I don't have anything to go on there. (HTO-06 spec only applies to 5w-30, i think)
Quick FYI for those of you that get the A01 filters from H and A, they have 40% off standard shipping right now.
FYI, we've had issues with them in the past and the current batch have a smaller amount of oring/gasket squish before mechanically bottoming out (compared to the A02), and a couple have failed to seal and ejected oil on startup (something the techs haven't seen with the A02).
