Just got my Ridgeline and as with all my Hondas I love it. It's an 08 with 70,000 miles and looks and runs perfect. Got it from a dealer for $11K out the door. But I don't know much about the trucks history. I want to change the tranny fluid but never done one on a Honda. I used to have service do this for me on other Hondas but I want to be doing this myself. I have always done my own motor oil changes with full syn oil and want to make sure the tranny is top notch cared for.
So, with no tranny filter, what is proper procedure for the change and what oil should I use? I will spend top dollar for better oil than factory if there is any such thing. If I drain the oil, should I run a bit and do it a couple times for better results? Also, I have an 05 Pilot with low miles and have noticed a slight shuttering when going from gear 3 to 4. Thought a good tranny oil change may improve this. Does the Pilot share the same motor/tranny as the Ridgeline? Thanks so much for the help, guys.:act035:
